Page 14 of 17 FirstFirst ... 4 12 13 14 15 16 ... LastLast
Results 131 to 140 of 166
Thread: AWD Conversion How-To
  1. #131
    Pittsburgh, PA
    so youre using your stock 4l60 harness thats been repinned to work the 80e? what are you doing for the rear speed sensor on the nvg149? if so do you have a link to that thread for wiring?
    Quote Originally Posted by zeake View Post
    I am using my stock automatic 5.3 harness. I used kysilverados 80e swap thread for the wiring from pt.net. My Front driveshaft is a stock reg cab short bed shaft. The key to the input gear is machining "I think". The only way I know for sure that it will work is the input gear from timetokill on sivlerado ss .com He works for the company that machines the input gear. I think they have a salvage yard also. My rear driveshaft is custom from http://www.pstds.com/. Hit me up if you have anymore questions. My memory is real fuzzy on it right now. It has been a while since I did the swap and I was not the mechanic for the job. I just got the information for my technician.
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
  2. #132
    Mar 2012
    so how much do you say you spent and my truck is a manuel 4x4 so would i leave the lever on four high
  3. #133
    I spent close to a $1000.00 if I remember correctly. Might have have been more.
  4. #134
    What if you put a quadasteer axle, that would be unique, not necessary, but cool to be able to say it is awd and aws.
  5. #135
    Quote Originally Posted by 03whitez71 View Post
    I wanted to butI would have had to spend wayyyyy too much. Also the bcm and controls for the aws would be dificult with out a complet donor truck.
  6. #136
    Hm...gotta find me a wrecked donor truck...
  7. #137
    You should write it up. I wish I could get a 2500 hd with a dmax and quadrasteer.
  8. #138
    To buy or mod?
  9. #139
    To buy or mod?
    If you are referring to me I want a 4door ccsb duramax. I am over the tiny interior and all that crap. I want a nice truck and then a vette to get my speed fix from. I have to wait for a few years though.
  10. #140
    did you ever sell your truck ? i saw you had a sell thread but didn't ever see if you had sold it. ya dmax's are pretty expensive, was looking for 06-07 classics with the lbz and with 100k miles they are around 23-28k around here, and by no means would i have a rcsb for a dd, my wife is prego so i will have to keep my ecsb z71, may eventually get a ccsb, would love a dmax but don't like the prices of them. and it seems like i am looking at about 15k for a denali part truck and a gmc rcsb truck to do this swap to, unless i can find a rolled or rear ended 02-04 denali
