Page 17 of 17 FirstFirst ... 7 15 16 17
Results 161 to 167 of 167
Thread: AWD Conversion How-To
  1. #161
    Sep 2009
    NE Ohio
    Wish I could do this to my OBS. I have all the AWD components from a 01 Denali.
    If I can only make it fit I would do it. Within monetary reason that is. Maybe I will keep all the components for future use.
    Been lurking since 09 and I finally have my kickass 6.0 LQ4
    LQ4 LQ9 6.0L Engine Service Manual Save to your computer in case it disappears
  2. #162
    AWD on OBS?
    Will the same SSS/Denali transfer case and front differential work on an OBS, specifically a pre-98 truck? I've got a pretty good deal on a 96 2 dr Tahoe with 4wd (the one with the dashboard switches) and was thinking of making a later model Typhoon-type vehicle? Autocrossing with a 2 dr Tahoe and AWD might be a ton of fun. As well as making a neat street vehicle.
  3. #163
    Mar 2012
    If I was converting a 2wd to AWD this way, does anything need to have electronics? I bought frame and front suspension from a 4x4 for $200 and I was just going to swap the body and rear axle over. And yes I know it's easier to to just buy a 4x4 but I have way too much money tied up in this truck and would take a huge loss selling it and for only being labor it doesn't seem like a big deal. Anyways, if I use the 149 and the SS front differential it appeared as though there were no wiring necessary for me to add?
  4. #164
    Dec 2008
    marshall illinois
    20151001_144955.jpgI know this is an old thread. I have kind of been wanting a 2wd just like 03 Z71. Maybe going AWD is what I need. I can have the lower stance I want and still have the AWD. I have the auto option on mine now. Hmmm. I bought the truck with a 6.5" lift and tired of it. Rough riding sob. I like the truck itself and color. I like that it has the cat eye front with the sport side bed. I just wanted a 2wd but this might work.
  5. #165
    Dec 2008
    marshall illinois
    Does anyone know what was done to the OP's suspension? It looks like it was lowered a little from the factory 4wd stance.
  6. #166
    Quote Originally Posted by 85 silverado View Post
    Some how, I did not get a notification for this. All that was done was the keys cranked down all the way.
  7. #167
    تعتبر صيانة السيارة أمرًا مهمًا للحفاظ على سيارتك تعمل بشكل جيد وللتأكد من أنها تعمل بكفاءة. هناك بعض الأشياء البسيطة التي يجب أن يتمكن معظم الأشخاص من القيام بها في المنزل والتي ستساعد في الحفاظ على حركة سيارتك.
    مرشح الهواء
    عادةً ما يمنحك دليل المالك فكرة عن مدى تكرار تغيير مرشح الهواء ، ولكن عادةً ما يكون ذلك مرة واحدة في السنة. مرشح الهواء مستقيم إلى حد ما ؛ حدد موقع الصندوق الذي سيكون عبارة عن صندوق بلاستيكي أسود كبير بالقرب من المحرك. سوف ينفصل هذا بسهولة إلى حد ما باستخدام مفك البراغي ويجب أن ترى بعض الأغلفة المعدنية التي تثبت مرشح الهواء في مكانه. فقط قم بفتح هذه الجوائز واستبدال الفلتر ، والآن فقط أعد إرفاق الصندوق وأنت انتهيت. هذا من شأنه أن يوفر لك 20 من المرآب المحلي الخاص بك.
    شمعات الإشعال
    تحقق من شمعات الإشعال أثناء صيانة سيارتك للتأكد من أنها لا تحتاج إلى وضعها أو تنظيفها. يمكن إزالتها باستخدام مفتاح الربط وإخراجها بسهولة إلى حد ما. بمجرد إزالتها ، افحص شمعات الإشعال بحثًا عن أي شقوق واستبدلها إذا وجدت. يمكن أن تتسخ شمعات الإشعال القديمة إلى حد ما مما يقلل من جودة عملها ، ونظف الأطراف برفق بفرشاة سلكية لإزالة كتل الأوساخ. هذا من شأنه أن يساعدهم على الاستمرار لفترة أطول قليلاً قبل أن يلزم الاستبدال.
    مستويات السوائل
    كجزء من الصيانة الدورية لسيارتك ، يجب أن تتأكد دائمًا من زيادة مستويات السوائل لديك. بعض هذه العوامل يمكن أن تلحق الضرر بسيارتك إذا تُركت لتصبح منخفضة للغاية ، مثل سائل تبريد المحرك والزيت ، والبعض الآخر يمكن أن يجعل سيارتك خطرة على القيادة مثل سائل الفرامل ، وسائل التوجيه المعزز ، وسائل غسيل الزجاج الأمامي. يسهل التحقق من كل هذه الأشياء عن طريق رفع غطاء المحرك والبحث عن الحد الأدنى والحد الأقصى من العلامات التي ستكون موجودة على كل منها. قم بتزويدها إذا لزم الأمر ، ولكن إذا كنت تتصدر سوائلك باستمرار ، فقد يكون هذا أحد أعراض مشكلة أخرى ، لذا قم بفحص سيارتك.
    الإطارات
    أخيرًا ، قم بفحص إطاراتك للتأكد من أنها آمنة. أولاً ، يجب عليك التأكد من أن إطارات سيارتك لا تحتوي على أي قطع أو حفر مفقودة من جدار الإطار. يمكن أن تتمزق هذه الأطر مما يؤدي إلى انفجار الإطار. يجب عليك أيضًا التحقق من أن المداس عميق بدرجة كافية. ينص قانون المملكة المتحدة على أن مداس الإطار يجب أن يكون على الأقل بوصة عبر ثلاثة أرباع الإطار. من المهم الحفاظ على إطارات سيارتك منفوخة لأن الركض على الإطارات المسطحة سوف يستهلك المزيد من الوقود ستحدد إرشادات المصنّعين مستوى الضغط لنفخ إطاراتك أيضًا.
    يجب عليك إجراء فحص لسيارتك كجزء من الصيانة الدورية لسيارتك ، وإذا وجدت مشكلة ولم تكن متأكدًا من كيفية إصلاحها ، فاستشر ميكانيكيًا في أسرع وقت ممكن.
    ورشة سطحه الرياض
    صيانة اودي الرياض
    صيانة مرسيدس الرياض
