i am looking for a ls2 90mm throttle body for an 02 4.8 chevy aswell as 42lb "direct swap" injectors. i have searched but i have not found anything that i liked
that is a 90mm throttle body off your lq9?
'04 Silverado RCSB with a crank bolt.
You know your truck sounds good when cops ask you to get on it.
Idle Clip
its a drive by wire chevy what year ls2 02 and sooner right?
Some older than 03 have the 1st design DBW. Can't tell by the year other than them all going electric on the newer ones.
If your'e wanting the LS2 '05-'06 Gto's and I think '05 and up Corvettes. Also look to pay around $200 - $250 plus shipping for these. They are not cheap. I got some friends that may have one if you are serious. Don't want to track one down and you say nevermind changed my mind. But if you are let me know and I will find one for you.
Idle Clip
i found some injectors on Buy Ford Racing Parts! what should i be looking to make sure that they will be a direct swap?
Is this what your looking for? I think its from an LS3. Let me know, I was about to put it on ebay. What intake are you gonna use? I'm pretty sure a 4-bolt TB won't bolt up to a truck intake. I also have a set of injectors, I think there 42lbs. but not sure the part number is 12576341.
1991 Silverado-L33 5.3L, 212/218 .557 .562 115+4, ASP under drive pulley,180* thermostat, 90mm truck intake w/ LS3 throttle body. Shoenfeld conversion headers and duel Flowmaster exhaust. Performabuilt LVL 1 transmission and 23-2500 stall converter.
No 42 pound injecter will be plug and play. You will need to have adapters to hook up injectors to your harness. And you will need to retune to the injectors.i found some injectors on Buy Ford Racing Parts! what should i be looking to make sure that they will be a direct swap?
No, the TB won't bolt to a truck intake unless it is a TBSS, (sure he knows this). And the injectors you have are 41.7 pound LS7 injectors.Is this what your looking for? I think its from an LS3. Let me know, I was about to put it on ebay. What intake are you gonna use? I'm pretty sure a 4-bolt TB won't bolt up to a truck intake. I also have a set of injectors, I think there 42lbs. but not sure the part number is 12576341.
Idle Clip
