how can i tell the difference????
is the LQ9 better than the LQ4???
4 - dished pistons
9- flat top pistons
01 Silverado
Use a bore scope to check the piston type. Earlier 4's had weaker rod bolts or something too. Some of them have different cams. The 4's were in everything under the sun therefore there are a million versions.
well im buy a compelete one so there is really no way of tell right?
pull a spark plug and look in the cylinder with bore scope. theres probably some casting numbers on there somewhere that will be able to tell you too, but im not sure.
01 Silverado
i have a 2001 chevy did a 4.8 swap to a 6.0l with mahle pistons 10.5:1,eagle 6.125' h beams,232 238@50.595 598 lift on a 112lsa,243 heads,44lbs motec IIs,tuned by Nick D,it makes 402rwhp,@5000lbs w/ me in it 13.75@101mph on 22' wheels
good idea blazed
04 1500 5.3L custom hp tuners tune by myself don have a pic of it yet so hear is my old 01 chevy 5.3 460hp 13.669 @ 116
i used a very small pin light in the spark plug hole on mine to see if it was 4.8 or 5.3
