Results 1 to 8 of 8
Thread: Drag wheels/tires
    Saint Marys, GA
    Drag wheels/tires
    I'm looking for some track wheels/tires for my truck. After just buying a new set of tires for my 20s, I don't want to burn all the rubber off those so I'm looking for at least a DOT, maybe a slick. What are most you guys running out there? I can't figure anything out because my truck has a 2/4 lowering kit and the wheels are on 265/50/20s and that's a 30.5" tire.. so most likely I'll have to get a smaller front wheel too where my front end won't be a lot higher. Any advice is appreciated. Thanks
    Current Mods: 6.0/4L80e with Trick Performance Front Mount
    Audio: Pioneer avic-d3, Memphis Belle, Two 12" Rockford Fosgate P3 shallow mounts, Memphis MS-Qs, and custom vinyl enclousure.
    Oct 2007
    Bandera, TX
    get some stock 16s and the hosier slicks. hook great, last, and are 28'' tall so wont look so bad on the truck. and they can be run tubeless. If it is a track only setup, go slicks. my
    single digit street truck
    for build info
    Southern WI
    +1 with mic
    Mike
    2000 RCSB
    '05 LS2 11.5:1 C.R. l K&N l LT's l Torquer V2 l PAC Springs l Manley 7.4's l 92mm TB l LS7 Lifters l Circle-D 3200 l P&P TB l ARP Rod Bolts l LS1 E-fans l Nelson 93 Tune l Brand-X 100 Shot l Walbro 255 l Duals w/ X and Magnapacks l Vette Servo l Transgo S.K. l 30K Cooler l Detroit Tru-Trac l Motive 4.30's l ARP Cap Studs l TA Girdle
    Pittsburgh, PA
    for a boosted application DRs all the way. i run a 295/65/15 MT DRs. you can run 15s and they are cheaper then other size tires.
    for skinnies you can run colorado spares. they are 16x4 and M&H makes the 27" front skinnies.
    yeah just run what I run. looks good and hooks
    RGV<<<>>>TEXAS
    nitto 555r most deff i got them in 305/35/20 hook real good
    Feb 2009
    mississippi
    the stock 16 with slicks work well that what i used on the old truck i got the rims for free from a buddy that works at a dealer
    04 1500 5.3L custom hp tuners tune by myself don have a pic of it yet so hear is my old 01 chevy 5.3 460hp 13.669 @ 116
    i run four 305/45r18 nitto 555rs on some titan 5 spokes. they are about 28.8 inches tall
    [Today 11:15 AM] MidnightRider: justin= generalvehicles.com moderator
