Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 25
Thread: transmission install write up
  1. #11
    I am going to add one thing:
    After everything is installed...let it idle for a minute...then oar through the gears...
    From P to R, then back to P
    From P to N, then back to P
    From P to D, then back to P
    Do this all the way down to 1. This will help get fluid everywhere before you go driving it.
  2. #12
    Branford, CT
    I knew I forgot something! possible sticky?
    2002 Z-71 ECSB-FLT Level 4, 6" Fabtech, 35's, all bolt ons
    1998 Cherokee, 4.5" lift, 31's roof rack, ARB bumper
  3. #13
    May 2006
    Waco TX
    I say put a sticky on it
    my installs usually go pretty quick and painless witht his
    Itll go atlest 8-10 ft in the air.
  4. #14
    yea that is alot of help but pulling that $$$ out is not a option everyone has. lol
  5. #15
    Branford, CT
    yea, I had to borrow the shop so maybe one day Ill own the shop and have a lift!
  6. #16
    May 2006
    Waco TX
    Quote Originally Posted by VenomHP View Post
    You got a sticky sir. Nice write up
  7. #17
    great write up.. but those connectors on the neutral safety switch you couldnt get off? they are weather connectors.. heat them up with the Mrs' hair drier, and the come apart easy.. you also heat them up with the hair drier to get them back together.. a little hint I got from FLT and Danny.
    Sponsored by Taylor Wires!
    Sponsored by PowerMaster!!
    Sponsored by FROZEN BOOST!
    Sponsored by US Speedo!
  8. #18
    May 2006
    Waco TX
    Quote Originally Posted by MidwestSS View Post
    I had to do that on mine. But my buddies 06 I installed the stall in a few weeks ago, I didnt have to use a hair dryer. The plugs were dif than my 03.
  9. #19
    They stopped putting glue in them in 04 or 05. Here's another tip, after heating them to get them apart, use some choke cleaner on the plugs to clean off the glue. You won't have to heat them the next time.
  10. #20
    Branford, CT
    that makes sense! Thanks for the sticky-Hopefully it will help someone one day
