Results 1 to 5 of 5
Thread: motor bracket problems
    i am in the middle of a motor swap from a 4.3 to a 6.0 and the driver side motor bracket does not line up i got v8 motor brackets from a junk yard the passenger side fits fine any ideas
    gotta get a mount for the driver side from a v8 truck. It bolts right in place of the v6 mount once you remove it.
    i did i got some v8 mounts and they mount different than the v6
    Mounts differently to the frame? Doesn't bolt in through the two tubular holes welded on the frame? Do you have pics of where you're trying to bolt it in?
    how do you mount the motor bracket if you dont use the factory tubular holes
