Results 1 to 8 of 8
Thread: newbe 5.3 question
    Dec 2008
    Hugo, Ok
    newbe 5.3 question
    i wanna replace my old carb 350 with a new 5.3
    what all do i need for it to run right and all my old gagues and cruise work still?
    Go here,
    LT1 Swap
    Look in wire harness info,great site with pinouts,and even how to wire the cruise with dbw setup.
    Dec 2008
    Hugo, Ok
    i seen that other day havnet looked all way through it.
    look like it has some good info
    Hutto TX
    search button homie. In the "LSX Truck Conversion" forum there are three stickies at the top of the forum you need to read. In addition, you should let us know what truck/engine/transmission/upgrades you have now. How "new" a 5.3 do you want, what sort of transmission do you want to bolt up? And finally, most importantly, how much $$$$ do you plan on spending?
    1991 Silverado ECLB
    LM7-T56
    Dec 2008
    Hugo, Ok
    ok ill read that
    i got a 84 silverado with a carbed 350 4 bolt main with 700r4
    cruise dont work like it is owner before me cut it out.
    otherwise its all stock
    i want to put a 5.3 or a 6.0 from a 00 or up
    either a 700r4 or a 4l60e which ever will work best
    and get my cruise to work again (never worked)
    i guess spend what it takes haha
    Dec 2008
    Hugo, Ok
    ok i wanna see if i got this right now.
    imma need motor with mounts, tranny, harness and pcm, inline or intake fuel pump,and a different way to hook the cruise control up right?
    Dec 2008
    san antonio TX
    im going the same route you are im going to swap my carbed 350 in my 82 c10 for a 5.3L im going to go look at the motor tommorrow. this is going to be my first ls1 engine swap.
    Dec 2008
    Hugo, Ok
    Quote Originally Posted by lechez71 View Post
    mine to tryin figure what all i need and so everything will work normal still
