Results 1 to 7 of 7
Thread: Axle shafts 14 bolt 9.5 sf
    Mar 2005
    Atlanta, GA
    Hey all,
    Looking for 5 lug axle shafts for the 9.5" 14 bolt SF rear axle. I know the 454ss had them, does anyone know what the p/n was, or where to get them?
    1991 c1500. 5.3l and 4l60e swap in progress, next paint and body.
    Currie or Strange may be able to make you a set. I sent mine to a machine shop and had them weld the holes in and then redrill for the 5x5 pattern. Cost me $155 for the labor.
    Mar 2005
    Atlanta, GA
    Just found out this came out of a 4wd mid 80's suburban. Anyone know if its wider than a 2wd version? The guy wants 125 for it.
    mine is about 1/2" more narrow than the 10 bolt. Best way is to measure it.
    Sometimes a 4WD rear axle is narrower.
    i thought the 4wd rears were about 3" wider, in the 88-98 anyway
    Track width is wider in the front than the rear on most K series and almost all T series dating back to the 80's.
