just bought a double din for my truck. need some help finding the right dash kit for it. radio is a pioneer avic d2. truck is an 06 RCSB non bose. TIA
dash kit is a metra 95-2003 and harness is a metra 70-2003 you will also need a antenna adpt it's a meta mdp-4 ok the harness you will have to run your own ign either got to the fuse box and tie into the wiper fuse or go to the column and tie into the pink wire not sure of the best or scoshe part numbers on the kit and harness hope this helps
Junkyard 5.3 milled heads 200 shot, built 4l80e with circle D 4000 multi disc converter
EPS cam 23x/23x 600/603 112lsa
KP 6 link bagged with Accuair E-Level
http://www.nitrousexpress.com/
FYI, I just put Nav in my Tahoe, GPS antenna works fine placed
on dash frame behind radio and UNDER dash pad.
Save much time, rather than mounting it outside somehow.
2002 Tahoe 4.8 - soon to be turbo'd - SOLD
1989 Mustang - LX Vert - 351W-TT - 2inches of dust covering it
2012 Raptor - 497rwhp at 10psi
If you aint breaking - you aint going fast enough
