Results 1 to 10 of 37
Thread: lt1 or ls1
    Arrow lt1 or ls1
    i was wondering with would be easier to swap. its a 1993 chevy silverado with a 4.3 liter and 5 speed trans. i was wondering if any one knows who makes motor mounts, and if i could keep my stock trans or not.any prices for parts of both motors.
    thanks.
    LS1 is the easiest. Any 4.8, 5.3, 5.7ls1, 6.0 or 6.2L engine will be easier than a LT1 swap. More parts are available for them plus you have us here for help.
    The LS is a much better design as well.
    Crossett,Ar
    I never liked the flawed idea of optispark being located under the water pump on the lt1. Its a disaster waiting to happen even if you get the lt1 swapped in. I vote LS style
    03 Silverado- 5.3 Fully bolted, Cam, Gears, Built 4l60, 100 shot
    Best E.T. - 13.62 @ 101.85 with a 2.0 60ft
    welcome to ls1truck!! LS all the way!!
    Heavily Modded NA 6.0 STOCK short block BUT Still Street Friendly @ 480+/440+ and now closer to 500
    BEST:
    ET: 11.39
    60FT:1.52
    1/4 MPH: 118
    Bakersville, NC
    GENIII all the way. the LT1 was good in its time but IMO is way out dated. and like show&go said the distributor is an ax-cident waiting to happen. 1 time with this happening and youll regret going with a GENII.
    David,
    2003 Denali, AWD, AWS, 6.0 LQ4, 4L65E, 4.10's, BBK 80mm TB, home made CAI, E3 spark plugs, MSD 8.5mm wires, 160* T-stat. Wheatley Performance Tune, DPT Long Tube Headers " There's no replacement for displacement"
    Rubber, 265/75/17 Fuzion XTI, Optima Red Top, Wagner Thermo Quite pads,
    What Red Said.
    Ls1 FTW
    99RCSB Sway bars bear brakes Mcgaughys lowering kit. Trick turbo, comp cam, patriot dual gold springs. Huge Oil cooler. 02 PCM, new FLT 4l85 PI converter. Handles like a vette but is faster. Yea its AWD. I still tow a trailer. TBSS for the Mrs. Yes I am likely to misspell a word or too and am not likely to be grammatically correct. No I don't care. 208º/214º .554"/.559" with a 114º lobe center .I need a better cam.
    LS1 is overrated.
    I would go with the LT1. More power for your buck.
    NP CHARGED
    There's one in every bunch.
    LS1 is overrated.
    Hey who took over Davids account. He has never owned an LT1.
    Least I don't think he has.
