Results 1 to 10 of 10
Thread: run your car on water
    wichita falls, tx
    they didnt hide the plans very well....
    Run Your Car on Water - Download Page
    Intro Radicalli's
    Sallisaw OK
    thats pretty typical of websites about something other than computer tech, most car sites in general dont have very good websites.
    1996 gmc ext cab short bed
    6.6L 4l80e
    MY GARAGE
    ff_jeff Guest
    Wow. That's good info. But a very complex system. I bet it is a PITA to build. probably would take the common guy a while to make too. I like the idea about the throttle activated current though. More throttle = more electricity= more HHO. Bad part is like all HHO cells that make decent Amounts of gas... they boil the water and steam kills the whole process. Not to mention if you don't have water in the cell while its on, you could have some problems. If you used the water as a conductive fuse, if you run out of water... no electricity is made. Great find Banker99... That's awesome. I already saved it to my desktop as a reference on my cell... Thanks.
    Alabama
    website no worky
    2007 Silverado. Mostly stock...
    AZ
    linky no worky
    '01 ECSB Red 2wd
    7" lift on 17" Eagles and 35" Pro Comps pc'd satin black
    de-badged, smoked tails, grille inserts
    5.3, 91 tuned, cold air,TB spacer, Thorley LT headers, 3" Flowmaster
    4.56 gears, posi-trac
    And more to come
    ff_jeff Guest
    Because they figured out the loop. If yall want this info, I saved it on My CPU at home... I can post it back up. But personally, It looks way too complex to me. At least for a supplement cell.
    wichita falls, tx
    yeah its on my harddrive at work ...if you want it pm me and i will send you the plans in a zip file...(they are a pretty big pdf file)
    Intro Radicalli's
    ff_jeff Guest
    did you ever try building it?
    wichita falls, tx
    ha...NO...that thing looks way too complicated....if i had paid for those instructions i would be pissed!!!
    Intro Radicalli's
    ff_jeff Guest
    Quote Originally Posted by banker099 View Post
    see...
