Results 1 to 10 of 13
Thread: Socket to remove seats?
    Southern WI
    I want to get a set of racing seats and harnesses for my truck, but I don't know the exact size of the socket or where to get it to remove the seats. It's the external torx socket, I believe the E16 fits the nuts that hold down the console and inside of the seats, but the outside nuts are bigger...is it an E18?
    Mike
    2000 RCSB
    '05 LS2 11.5:1 C.R. l K&N l LT's l Torquer V2 l PAC Springs l Manley 7.4's l 92mm TB l LS7 Lifters l Circle-D 3200 l P&P TB l ARP Rod Bolts l LS1 E-fans l Nelson 93 Tune l Brand-X 100 Shot l Walbro 255 l Duals w/ X and Magnapacks l Vette Servo l Transgo S.K. l 30K Cooler l Detroit Tru-Trac l Motive 4.30's l ARP Cap Studs l TA Girdle
    Its one size bigger than the E18 I believe, but you can also use a metric size(non 6point) on the seats. I bought a set of the external sockets to remove my seats, but they werent big enough on one side so I used a metric size
    I just used the metric 12 point as well
    Bakersville, NC
    Mine was the E16, they should be the same for every truck. At least thats what the dealer told me.
    David,
    2003 GMC Sierra Denali, LQ4, AWD, AWS, 4.10, Wheatley 93 tune, LT headers, GMPP CAI, BBK 80mm TB, MSD wires, E3 plugs, 160* T-stat, Flowmonster DI/DO, cutouts. Working on 4.8 heads, just purchased Comp 228R cam, 918 Springs, TI retainers, 7.4 hardend pushrods,
    Union, MO
    I am wanting to remove my middle seat too. Does anyone have a picture of that it looks like removed? Didn't know if brackets would be sticking out like a sore thumb.
    2010 Silverado ECSB LS 4x4. Only mods so far are a K&N drop in filter and a Rough Country 2" front level kit
    Nov 2006
    Mesquite, TX
    im thinking it take a 11mm 12 point and 14mm for the bigger ones...its been a while
    number 11 for the back 2 bolts number 15 for the fronts, youll need a deep 15 for the fronts 12 points preferebly ive only done this a few hundred times
    and to answer medics Q? you have to take out both seats then the console will just come out brackets and all then jsut put the seats back in there is no left over brackets, im the master at stripping interiors hahahah
    Yep ^^^
    There's a special socket from GM for those inverted Torx but I simply use a 15mm deep 12-point 'cause I'm too lazy to walk 50' and get the proper tool.
    Nov 2006
    Mesquite, TX
    oh you can get the console out without removing the seats...trust me
    But it's a lot easier to remove the seats to get the console out ..especially if you want the console brackets out (they're under the seat frame).
