Results 1 to 5 of 5
Thread: Stripped screw or bolt removal (helpful tip)
    Sallisaw OK
    While changing a solenoid in my transmission a torx style bolt stripped out.
    To avoid having to drill and tap it out, i cut a slot across the head with my dremel cutting wheel and was able to remove it with a large flat screwdriver.
    while this may not work for every situation it is much easier then drilling it out, especially when in tight quarters.
    1996 gmc ext cab short bed
    6.6L 4l80e
    MY GARAGE
    good deal glad ya got it out!!!steady hand and a dremel does wonders!!
    Simple: 408 on steroids!
    single digits coming soon!
    Hurley, Mississippi
    I did this on a bed bolt, and it worked well.
    '86 Silvy- '06 6.0/4L80E, K&N, 2.5 X-pipe Magnaflows, 20" Foose Wheels, Auburn Pro, 3.90 Richmond Gears, and the list is growing!!!
    ff_jeff Guest
    Great idea. I have done this before on a Philips screw. Its called fundamentals of making **** work!!! lol
    Man you ripped the crap out of that head! It could almost pass for a socket head bolt. Good tip, I'll have use for tha no doubt.
    Bob
