Results 1 to 10 of 11
Thread: Throttle body spacer ?
    Okeechobee, Fl
    I can get a used 1" tbs for $50 from a buddy he said it helps gas milage and helps alittle on bottom end. Is it worth the money?
    Ripon, CA
    tap it for nitrous use.
    2005 rcsb silverado 4.8L, Full bolt ons, obx lt's, ory, comp xr265hr hi lift, Nitrous outlet plate kit, built 4l65e, J-H shift kit, 2500 stall,3.73 G80 , 3 inch spintech cat back, tuned by Rick at Synergy motorsports
    Wasilla, AK
    Quote Originally Posted by hwyto666 View Post
    That is the only way that it will really make any difference.
    2001 ECSB 4x4, 5.3, Radix, 3.0 pulley, VHP Trucker cam, 216/224 .551/.551 115 lsa, 1.8 Crane roller rockers, 4L65E, Yank SC3000, 3.73, Cal-Tracs, HPTuners.
    S.A. Texas
    you could sell it for aluminum scrap but i dont think you will get 50 bucks
    Mar 2006
    Mesquite
    I believe Greg picked up a mile or two per gallon with his. That's worth it in my opinion.
    Didn't change my gas mileage that I know of. I rag on the truck too much to ever check fuel mileage. It did however lower my ETs. The spacer got me down to 8.009 in the eighth with no other modifications.
    Birmingham, AL
    i havent noticed anything except a cool whistling noise
    01 Silverado
    Mar 2006
    Mesquite
    Must be you said it got you down 1 or 2 tenths...I know there was a 1 and 2 in there...
    you guys are kidding right....... greg you have a nitrous dave plate, what the hell is goin on..... no dude its not worth the 50 $
    I swear on my life that my times picked up when I put the spacer on and no other mods. No spray ran through it to improve the times either. I don't understand it because its a straight through bore. I do have an LS2 intake and 90mm TB though.
