So true, that 100k+ unit wore out. Now I have a fresh one that has been taking a beating so far. Theres nothing like breaking them in right.
Hey i was wondering if i got a 4l80e for my RCSB if i would have to make a custom driveshaft? or could i just go to the junk yard and find out that will fit out of another car? Thanks
04 Silverado RCSB
02 LS1 Shortblock(Stock)
LS6 CAM - 204/219 .551/.548 117.5
243 Heads w/ Light Weight Valves
Exhast- LT Pacesetters w/ory, 3" Straight pipe
Suspension- DJM 4/6, Doetsch Shocks, Caltracs
Need a ported DBW TB > http://www.ls1truck.com/forums/sale-...ale-trade.html
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
Eric "The" Pyles
14.06 @ 96mph / 9.02 @ 79mph
302 RWHP/298 RWTQ
Don't cut anything until you measure the difference in transmission lengths measured from the bellhousing to the output shaft end. Also, be sure you get a splined slip joing type output shaft, not the one that bolts on. There are two different ones and you won't know the difference unless you take the tail housing off or have a long slip yoke to slide on it before you buy it. They both are tapped for a bolt.
Check out this post for what I'm speaking about.. http://www.ls1truck.com/forums/mecha...tml#post143824
I did the 80e swap in my RCSB you will only need a shorter slip yoke to make the drive shaft work and you can get it online pm me if you need more info.
A.J.
RCSB GMC SIERRA 00
What size fitting did you use to convert the hard line to the AN fitting?
For those that are comfortable cutting and splicing wires or re-pinning a connector, you can do this method instead of spending the extra coin for a conversion harness. You'll still need the harness for the second VSS, but this takes care of the main round harness that plugs into the side.
2006 GTO M6 Brazen Orange
2006 Silverado CCSB Duramax
