Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 25
Thread: Crankshaft System Variation Learn Procedure
  1. #11
    Lakes Region NH
    Red, I have a tuned PCM and never did the crank relearn, however my truck has no DTC's. Ive checked it with Auto Enginuity as well as a pocket scan tool. Will performing a crank re-learn waken anything up? Make any difference? The PCM is a second PCM, not my stock unit.
    Ill grab some ditch to get a cat...
    03 Silverado ECSB - SOLD
    06 CCSB Duramax - 12 second tow pig
  2. #12
    It should not make any difference if you do a crank relearn on an engine with no codes. The most it might do is reset the PCM to as new installed and then it will have to relearn all functions all over again, losing you power and fuel mileage for a little while.
  3. #13
    Lakes Region NH
    Thanks! Good to know, I learn something new here every day.
  4. #14
    It can learn itself by driving but usually the CKP relearn is needed if there are DTC's.
  5. #15
    Mar 2006
    anyone in NW houston neeing the relearn just pm me.
  6. #16
    Mar 2007
    in HPtuners, my tam never goes up 86 F so it never let me do the relearn procedure......anyone can help me please?
  7. #17
    TAM? what is that? If it is the water temp, go to you local electronics store and get a variable resistor, disconnect the water temp sensor and wire it in. Turn on the scanner and see what temp it shows and then adjust it to get it to the temp you're wanting.
  8. #18
    Mar 2007
    Yes, Temp.....but my tem sensor in the OEM gauge is OK, and in the scan also is above 185......only in the bi-controls only rise to 86F like if it is reading in C instead of F.
    Radio Shack will sell what u mention?
  9. #19
    yes, sounds like you need to configure your control settings to NON-metric scale output
  10. #20
    Mar 2007
    it is in Imperial, not metric !!!!!
    Any other place to look?
