Page 3 of 3 FirstFirst 1 2 3
Results 21 to 24 of 24
Thread: 4.8 to 6.0 Engine Swap
  1. #21
    May 2010
    deer park
    4l60e Transmission Problems
    Question I Have A 2000 Silverado Single Cab Did A An Engine Swap From A 5.3 To An Ls1 Out Of A 2004 Vette Ever Since Then My Transmission Pump Keeps Going Out It's Fully Bolt On Cam, 2700-3000 Circle D Stall 390 Gears Any Suggestions?
  2. #22
    Dec 2010
    How did you get the cruise control cable off of the throttle body?
  3. #23
    Nov 2011
    NH
    i did this swap to and got a 99 6.0 for my 99 sierra to replace the 5.3 .. turns out you need a 01 or newer or that spacer that you can remove to run the 4l60e is built into your crank and its you cant remove it... so your stuck swaping the 4l80e into it....
  4. #24
    Contact Circle-D and tell them your setup and they can build you a custom convertor to work with your early 6L/60e combination. Going to 80e would be good insurance, too.
