Page 15 of 15 FirstFirst ... 5 13 14 15
Results 141 to 149 of 149
Thread: LS6 Intake Swap
  1. #141
    so, run the fuel straight to the rail, on the opposite side fuel rail add an Aeromotive FPR and then vent the excess fuel back to the tank. Easy peezy lemon squeezy.
    Aeromotive 13101 - Aeromotive A1000 Injected Bypass Fuel Pressure Regulators - Overview - SummitRacing.com
    Aeromotive 13105 - Aeromotive Compact EFI Fuel Regulators - Overview - SummitRacing.com
  2. #142
    Oct 2009
    Reidsville, Georgia
    Hey hey! I like those, pretty nice pieces, and looks like that'll do the trick Greg, man this site is great!
    2000 2-toned silverado, Totalled. Gone But not Forgotten.
    Now: 2002 black rcsb chevy. 5.3, P&P 862's, Comp 224/230 .58*/.59* 114 LSA, Racetronics 44lbers, ARP 2000's, Ebay long tubes, 4L80E, 3800 yank pro, transgo HD-2, 4.10's, True-Trac, Walbro 255, Nitrous Outlet plate setup for 200, 80mm BBK, 3" Magnaflow, and Raggedy traction bars! Waiting to be istalled, F.A.S.T LSx intake..........
    Best: 7.40@90 1/8th
    Tuned by: DIXIE PERFORMANCE
  3. #143
    We try.
  4. #144
    hey i just got put a bbk ssi on my 5.3 with bigger injectors i cant get it to idle
    do i need to get it tuned it also has a cam and it has been tuned for it what do yall think
  5. #145
    Oct 2003
    Navarre, FL
    I'd like to know about the BBK SSI too...I'm wanting to use it too
  6. #146
    Oct 2009
    Reidsville, Georgia
    You should probably have it tuned, with bigger injectors and that in take flowing more the idle characteristics have changed form what they were, so i'd say get her to the tuner!
    Best: 7.40@90 1/8th
  7. #147
    Oct 2010
    Lubbock TX
    Does the stock size belt work with this after you relocate the idler pulley?
  8. #148
    Jan 2007
    Lewisville,TX
    02' 4.8/5.3 with ls1 intake and stock water pump using truck TB. I dented the water neck, cut off the cruise control cable nipple off the TB, will trim the cable guide a little too. Only mocked up now but looks as if it will work. Saves having to change the water pump.
  9. #149
    Wear a diaper on the first road test in the event the throttle sticks open.
