Results 1 to 7 of 7
Thread: Throwing some codes.
    Well I just got the 5.3 in and after putting about 7 miles on it I threw 3 codes. Im only running longtubes and ORY right now.
    - PO151 HO2S CIRCUIT LOW VOLTAGE BANK 2 SENSOR 1
    - P1153 HO2S INSUFFICIENT SWITCHING BANK 2 SENSOR 1
    - PO507 IDLE SPEED HIGH
    I think the first two are related to oxygen sensor, I replaced the one on the driver side, so its brand new. One on the pass. side is from the V6.
    Also when ever im driving it, Ill come to a stop and itll sound like its going to die and then jump up to like 1100 rpms. Any suggestions as to what that might be?
    Either a dead 02 sensor or blown fuse in the 02 heater circuit. Buy sensors for the rear 02 in a late model Corvette. Are you using a factory wiring harness or the Nelson harness?
    Also, check all your grounds that they are tight and wires didn't break.
    I am using the factory harness. Do you know which side it is referring to that would be bad? What about the idle speed high code?
    Passenger side 02. Check for vaccum leak, Could cause your idle issue and 02 issue. Could be bad 02 and IAC problem carbon/dirty etc... If you have HPT, EFI or a scan tool you can command position to test IAC
    Jan 2005
    Humble/Houston TX
    before replacing anything get the exhaust buttoned up and some hands on tuning IMO
    old mod list: H/C/I/N/E/G 408
    San Marcos Texas
    You could also swap the o2's right and left and see if the problem moves.
