Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 40 of 40
Thread: 6L85E Specs, Info, How it Works
  1. #31
    Sep 2009
    Quote Originally Posted by sprayedenali View Post
    the only time i really like mine is when im towing.... otherwise... its always shifting and its a pain in the ass to deal with!!!!!
    Ah I see. What about fuel economy? Does it seem any better than it would be if there was a 4L60/80E underneath?
    2000 GMC Sierra 5.3L 4x4 ECSB
  2. #32
    Jan 2010
    Emmett, ID
    I wanted to do this as well, but was told that even if I can get a good deal on the tranny, im still going to spend mucho money to get it to work. Im sure on the 6.0s like mine you would gain about 2mpg.
    1999 Silverado 2500LD EC, SB, 4x4, LT, 6.0 V-8 (LQ4), 4L85E, 4.10 gears & a G80. 4" homemade intake, 3" magnaflow 2 into 1, diablosport predator tuner.
  3. #33
    Sep 2009
    Any new updates on integrating the transmission into older vehicles? Or is it still basically down to using a Gen IV engine and computer?
  4. #34
    Spring, TX
    Quote Originally Posted by admin View Post
    Torque Converter Size - Diameter of Torque Converter Turbine
    258/300 mm
    Are these numbers reversed?
    '02 Silvy: Z71 EC Step Side 5.3L Nelson tuned
    2013 GMC Acadia: SLT1 Carbon Black
    1976 Corvette Stingray: Trying to save it, progress is slow.
    ^Ricky's Sweet PS Skilz
    09/21/2010 02:31 <danger_ranger83> I'm not really worried about the looks...I want it to be fast and ugly...bc no one wants to get outrun by something ugly
  5. #35
    Feb 2008
    North NJ
    The knowledge base is already established to retrofit these to any MPFI OHV V8 motor, including Gen III/II/I (TPI)...the issue is finding someone willing to spend the money to do it and get the custom parts made. Fuel economy is a marginal gain. It along with the transmissions performance and overall reliability is a matter of tuning. From the factory they are tuned for fuel economy. Most tuners don't understand the inner workings of the 6L80/90's let alone the electronics, so when they apply 4L70/80 techniques to it...6L's go boom and then get a bad reputation.
    I've advised everyone with this basic thought. If you already have big power (over 500RWHP) and want SIMPLE & reliable..go built 4L80/85. If you want to go even faster with that power go BUILT 6L90. If you have under 500 WHP and want to go faster, just build your 4L70 find a good tuner and go 6L90.
    The whole benefit of the 6L80/90 is that you can go faster with a simple transmission swap without changing converters. You also get unmatched off the line, rockcrawling, heavy towing, and low end to mid range torque multiplication. It is through the gear torque manipulation in heavy towing that you will find an improvement in fuel economy. Just everyday, non-towing driving will not yield a significant increase in fuel economy.
    '07 TBSS AWD 6L90E Conversion and '07 TB "RS" 4WD 6L80E Conversion!!
    www.TBMsport.com
    True Blue Motorsport
  6. #36
    Nelson Performance did my 6l90e swap in my 08' rcsb silverado behind my cammed 6.0 along with 4.56 gears and runs badass with no issues!
  7. #37
    Feb 2008
    North NJ
    Badass isn't the word!!! lol...what does it dyno?
    www.TBMsport.com
  8. #38
    I have an LS3/6L80e out of a wrecked 2010 Camaro, no cam, no stall, just tuned. My truck(81 c10) will be a DD (only when I'm home from offshore) that sees the strip on occasion. It's halfway done, rolling chassis, starting wiring harness now. Can anyone recommend an optimal gear ratio for the rear end with my setup? I have 3.73 posi now, 29.5" tires...thx
    1981 C10 6.2LS3/6L80e - In progress
    http://www.ls1truck.com/forums/lsx-t...im-stoked.html
  9. #39
    Feb 2008
    North NJ
    3.73's are fine with that tire size. I have 29.70" and 4.10 in the SS and 3.24 in the 'RS'
    www.TBMsport.com
  10. #40
    Jul 2019
    Panama
    6L85E Specs Info How it Works
    As was already stated, probably the gas cap issue.
    I wont worry about using a lower octane of gas -- I use anything from 87-94 depending on how generous I feel at the pump that day and have had no problems including heavy towing, in high heat, with 87.
