Which fuel pump and injectors are the best bang for the buck. Going on a stock 4.8 with 6-psi, wanting to get rid of the FMU. Also what size are my stock injectors, and the rating of my stock fuel pump-just curious. Thanks Brett
<div class='quotetop'>QUOTE(2001silverado @ Jun 18 2007, 11:10 AM) [snapback]97127[/snapback]</div>Get a Walbro 255l/ph in-tank pump from TRT or Nelson. You can get a set of the 8.1L (31#) injectors for pretty cheap on Ebay. Or go with some Bosch 42# injectors. If you get a custom tune, have them cut back the 42# so they don't flow so high. You are probably running at 100% capacity on your fuel system with the Powerdyne---so get the bigger fuel rails too...Which fuel pump and injectors are the best bang for the buck. Going on a stock 4.8 with 6-psi, wanting to get rid of the FMU. Also what size are my stock injectors, and the rating of my stock fuel pump-just curious. Thanks Brett
[/b]
They haven't sold yet, but this second set of injectors are $250. Pump kit is $135
Nelson Performance
FastestTruckList.com
NP on Facebook
Youtube Channel
