Results 1 to 10 of 10
Thread: Yukon 6.0 at the track
    Apr 2007
    Surprise, Arizona
    Post
    ran a 15.475 @ 94.101 last night with my Yukon . it was still 100 deg at 11:45 last night.there was a lot of upset imports that were talking the crap and only runin a 16. they were surpised to get spanked by a suv.
    I will try to get the video up.
    05 Yukon 6.0 lq9, Corsa cat back, GM performance cold air intake, ls7 1.8 rockers,ls2 cam, Comp push rods 20" wheels, corvette servo, and Nelson Performance tune. and a 06 lbz Duramax ccsb 4wd leveled and 17" wheels.
    !!DON'T GO TO BED ANGRY, STAY UP AND PLOT YOUR REVENGE!!
    Oct 2005
    Baton Rouge, LA
    <div class='quotetop'>QUOTE(VIOLENTJR &#064; Jun 16 2007, 10&#58;03 AM) [snapback]96958[/snapback]</div>
    there was a lot of upset imports that were talking the crap and only runin a 16. they were surpised to get spanked by a suv.[/b]
    I used to do that all day long. Wife would get ticked about running ricers. My &#39;02 Kon ran a best of 15.91 (no mechanical mods). I can&#39;t seem to get one to run when I&#39;m in my pickup.
    Test-n-Tune (Nov 23, 2008) - 13.65s @ 98mph
    nice times got you updated on the fastesttrucklist. let me know if anythings missing
    Oct 2005
    drinking your alcohol
    put you a 100 shot on that bad boy and get down low
    DamnYankee: my nana failed
    Nov 2006
    Mesquite, TX
    <div class='quotetop'>QUOTE(TxStVanWilder &#064; Jun 16 2007, 03&#58;02 PM) [snapback]96982[/snapback]</div>
    [/b]
    screw the 100 shot, the 6.0 can handle a 200 shot easy
    2006 silverado SS....Clifford Jr...turbo coming soon
    1970 Chevelle ly6 swap....d1 coming soon
    Jan 2006
    Great job&#33; I love to see the faces of guys when a mini bus shows them the door. Have some vids of my Yukon before and after the AFR heads and meth injection...unfortunately, I spun the crank pulley off the same day I ran the 12 and filled the oil pan with metal filings. Need to pull the engine and replace all of the bearings now&#33; Lesson: pin the crank pulley if you run a Radix&#33;&#33;
    Before
    After
    01 Yukon 2wd, 547whp/576wtq @ 8 lbs - 383ci LS6, Eagle 4" crank, Crower rods, Diamond -7cc pistons, Speed Inc SC1 cam (222/228 566/571 114) AFR225 72cc heads, Crane Gold Race rockers, Siemens 60 lb inj, Magnuson MP122HH w/3.2" pulley, ASP 8-rib kit, Alkycontrol, 05 E-fans, Dynatech LTs, Corsa Touring catback, FLT Level IV 4L60, Yank TT2600, 3.42/G80 9.5" 14-bolt, Hotchkis swaybars, 275/45R20 Conti DWS06s on 20x9 Denali Repros. 12.574@110.593 1.82 60' VIDEO
    <div class='quotetop'>QUOTE(LS1Yukon &#064; Jun 17 2007, 08&#58;44 PM) [snapback]97071[/snapback]</div>
    Before
    After [/b]
    LS1Yukon---nice truck man&#33; Sucks to hear about your bearing mishap. Dude, if you would have asked first...Pinning the crank pulley is the number one thing to do when you have a Radix with anything under a stock 3.4 pulley. What kind of boost with the 2.85---12-12.5 psi? Congrats for hitting the 12 sec. mark&#33; Clean up that motor and get it back in there you so can have a few more 12 sec. passes&#33;
    I will try to get the video up. [/b]
    Good runs&#33; If it is that hot where you run, try a little meth injection. It will run cleaner and cooler. It is always good to see a heavy ass 4 door SUV spank some ricers....
    Jan 2006
    <div class='quotetop'>QUOTE(txarkitekt &#064; Jun 18 2007, 10&#58;10 AM) [snapback]97117[/snapback]</div>
    [/b]
    You&#39;re absolutely right...when I had the engine built, the builder asked me if I wanted the crank aned pulley keyed, and I ignorantly said "Nah&#33;" Would&#39;ve only cost me &#036;175 to have avoided this entire mess&#33;&#33;&#33; Like I said, lesson learned. I&#39;m seeing just at 11 lbs max boost at around 3800 rpm, then it slowly drops down to 8.5 lbs at redline. Not sure of the cause but I have since bought a 90mm j-tube/NW throttle body and 60 lb Mototrons, so I&#39;m confident that fuel/air won&#39;t be the issue next time out.
    And I can not recommend meth highly enough for the Radix...it knocks down the IATs and allows ALOT more timing&#33; Colby
    Apr 2007
    Surprise, Arizona
    [/quote]
    where is a good place to get some info on meth inj? prices, how it works?
    thanks
    &#33;&#33;DON&#39;T GO TO BED ANGRY, STAY UP AND PLOT YOUR REVENGE&#33;&#33;
    Jan 2006
    <div class='quotetop'>QUOTE(VIOLENTJR &#064; Jun 19 2007, 11&#58;39 PM) [snapback]97270[/snapback]</div>
    thanks
    [/b]
    Try the manufacturer sites first...they have some generic info that helps with an overview on how it works. Most will also give their reasons why theirs is best...some of which may very well be valid.
