Okay, I was speaking to someone regarding swapping out my 4L60E for the 4L80E. Aparently, the 4x4 version of the 4L60 and the 4L80 are about the same length (about 1-1.5" diff) and the 1500HD has the 4L80 behind it too.
I was told I need the following for the swap: 4L80 crossmember, trans itself w/ converter, and the flexplate.
Apparently my Autotrac transfer case will bolt up also as the 1500HD uses the same transfercase and the minimal difference in length will be taken up by the slip yolks.
I have the exact info at home and will post it up so it may make more sense.
Thanks!
