Hi,
Yesterday, I dropped my fuel tank out on my 88 Blazer and swapped out the old fuel pump with a new one that, for the most part, is nearly the same, except that it puts out 60 psi instead of 12 psi (doing an LS swap).
The new fuel pump's inner pigtail wiring wasn't a match with the Blazer's fuel sending unit. Both fuel pumps had two wires, so I attached the black wire from the new pump's pigtail to the sending unit bracket (where the old pump's black wire went); I then spliced the Blazer's other wire with the red wire from the new pigtail.
After submerging the new pump with the wire splice into 12 gallons of gasoline and sealing everything back up, two questions dawned on me:
1) is this going to work?
2) is this going to blow up, and if so, what would be the best life insurance policy I can get for my family?
Seriously - will there be any issues with the wire splice submerged in fuel? I imagine the metal contacts on the ends of the pigtails are no different than a metal splice case butting the two wires together, but then again, I'm really not that smart - just determined. Any feedback would be greatly appreciated.
Thanks.
