Page 6 of 9 FirstFirst ... 4 5 6 7 8 ... LastLast
Results 51 to 60 of 89
Thread: dropem's 5.3->turbo 6.0 swap
    just the stage one kit?
    wichita falls, tx
    no its the stage 2 with dual nozzels
    Junkyard 5.3 milled heads 200 shot, built 4l80e with circle D 4000 multi disc converter
    EPS cam 23x/23x 600/603 112lsa
    KP 6 link bagged with Accuair E-Level
    http://www.nitrousexpress.com/
    damn luckyyyyy.. are you gonna use the juice from them or washer fluid/water
    wichita falls, tx
    prob just washer fluid
    Quote Originally Posted by dropem View Post
    if its not too cold you could save yourself $1 and run just water
    Apr 2005
    The Woodlands, TX
    FYI, -20* WWF is about 30% meth , That's what I run, 30+ gals and no problems.
    01 ECSB 1/2 ton 4x4 6L GMC
    11.03@127
    KB Racing Borg Warner S475 turbocharged
    http://i3.photobucket.com/albums/y57/Kbracing96/kbracing96copy-1.jpg
    Quote Originally Posted by kbracing96 View Post
    I used that for a while, then during the summer months i just put water in. Ill probably go back to Winshield washer fluid as well
    wichita falls, tx
    ok, selling ticket to the big event tonight
    $10 general admission
    $15 for front row seats
    initial start up at 9p.m. 10/15/08
    Intro Radicalli's
    Sweet man--so everything is in and ready to rock? Get some vids! Also, I saw you mentioned gauges...you defintely need a Wideband to monitor the A/F ratio...along with an Aeroforce to watch the 87 quadtrillion other things...
    wichita falls, tx
    yeah got them both were ready to rock and roll
