Results 21 to 30 of 34
Thread: Need info. Has this ever happend or have you heard of this happening.
  1. #21
    Quote Originally Posted by danger_ranger83 View Post
    Yea but also there are different size bores for the bearings but most come with the instructions for where to install the bearings
    Yep, at least in the old days the bearings are smaller the farther rearward...so if the installer put the rear bearing in the front the cam won't go in.
  2. #22
    Feb 2010
    Odessa, texas
    If i remember correctly the middle is the largest and then 2&4 are a bit smaller then 1&5 are the smallest
    1983 Ford Ranger- 2.3 to 205k mile 6.0 swap
  3. #23
    Crossett,Ar
    Well with it off the engine stand and at the machine shope we got to play around a bit... If we try to insert the cam from the rear of the engine it works all the way through UNTIL it gets to the front cam bearing and it wont finish going through. The machineist feels he put the wrong bearing in cocked to a angle or something. So he is going to order a new front and all and handle it and get it back to me asap
  4. #24
    Paris, Texas
    lets just hope it is just the wrong set of bearings. old whitey needs to be at SAR
  5. #25
    wichita falls, tx
    Quote Originally Posted by sierraman View Post
    +1
    Intro Radicalli's
  6. #26
    Crossett,Ar
    I dont have enuf off days till right before SAR to get her running. So there isnt a chance it will make it to SAR cause I wont have time to secure a trailer and I doubt the tune will be lined out in just a few days. I hope to have her cranked and cruising just not ready for a 10 hour trip. This last Saturday was the hail mary day that if everything went right I may of made it. But... looks like thats all down the drain now. Another year of spectation
  7. #27
    Don't sleep. Wrench.
    Paris, Texas
    exactly, you just said it a 10 hour trip, let a friend drive while you sit in the truck on a uhaul trailer and tune it. that way you have nothing to distract you.
  9. #29
    Crossett,Ar
    You and Frenchy are insane lol. Ill keep working towards it. Just no promises
  10. #30
    Crossett,Ar
    Alright. So the machinist had the bearing in wrong. He got it fixed and back to me today. I got the camshaft put in but sadly I am sick as a dog so that is all I did today. Hopefully tomar Ill get the oil pump timing gears and all put on and then put the heads on this weekend on so on and so forth. Also for further reference. According to this builder the bearings ARE different. 1 and 5 are same, 2 and 4 are the same and 3 is different. That was the instructions he got for these bearings anyway.
