Page 3 of 3 FirstFirst 1 2 3
Results 21 to 25 of 25
Thread: front mount or rear mount?
  1. #21
    Aug 2005
    St. Anthony, Indiana
    Quote Originally Posted by Chevy-Art View Post
    Ducky, what are you using to measure the IAT's? Can I use it if I am N/A? Thanks Art...
    This is what we use, General Motors Interceptor Technical Information
  2. #22
    Yeah I use the aeroforce interceptor gauge to measure everything. Kind of sucks because I dont run it from the map so I cant read the cool things
    Blue Springs, Mo
    I would deff agree running the air filter into the bed if you dont mind cuttin a hole in your bed to do it. I did mine that way.
    2004 silverado rcsb 2wd cammed 6L, 3.42's, Hydroboost swap, 4l80e w/hd-2 and yank 3200, twin intank pumps, 60lb injectors, trick hot pipes/MP T76
  4. #24
    Walbro GSS341 is the fuel pump. Call nelson and get the 48# injectors with the ls1 clips. Run 10 psi.
  5. #25
    Thats the fuel pump only it was 85 bucks. I guess you can get the whole assembly for your truck right? That would be a lot easier.
