Page 23 of 32 FirstFirst ... 13 21 22 23 24 25 ... LastLast
Results 221 to 230 of 316
Thread: my official build thread
  1. #221
    Little update:
    I decided to go ladder bars and backhalf since it would be much easier to cut the rails and make new 2x4 rails rather than straighten the old ones and box them in. I just cut the rails and removed on leaf hanger. I have a 12 bolt from a 70-72 chevelle that my buddy gave me so i cut off all the brackets and have it ready to start fabbing up the suspension. Im going with 35 spline axles, spool, c-clip eliminators, and 3.55 gears. The 12 bolt is 6.5" narrower than the 10 bolt so no need to narrow anymore than that. Next thing to do is build the fram rails. Im going to narrow the frame about 3-4" on each side. That should give me enough clearance to run a 18" wide tire if need be haha. Here are a few pics
  2. #222
    Oct 2011
    San Antonio TX
    Cool deal. Keep us updated on ur ladder bar build. Also it looks like the frame bent right at the c-notch which might have actually saved the rest of the frame lol.
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
  3. #223
    Sep 2011
    Awwwww shittttttt!
    99 rcsb silverado...... boosted.
  4. #224
    That's what I was thinking. Acted as a fuse you know. I'll keep it updated. And if yall are on the pt.net fb group I routinely post pics there too. Name is Nick Sherlock
  5. #225
    Why? Because racetruck
    word. Going with a COPO Silverado theme
  7. #227
    Sep 2011
    It would be a good time to install a griner trans brake ..... Just saying!
  8. #228
    Yea it would but I'm going to keep the engine and trans how it is for now and see how fast it'll go. Trans brake will be either when the th400 needs a rebuild or when I build a motor and bigger turbo
  9. #229
    Well I just got back from working out of town and I had a bunch of parts waiting for me. I got the ladder bars and brackets, shock mounts, shock crossmember, some stuff for the 12 bolt, coilovers, SS bumper cover that I will be doing a little trick with, and roll pan
  10. #230
    Oct 2011
    San Antonio TX
    Yup this is gonna get interesting.
