Results 11 to 15 of 15
Thread: Fs/ft: 2006 tbss awd black
Threaded View
    2006 Trailblazer SS AWD LS2 - 110,310mi on Body -
    $14,000 OBO
    $13,500 WITHOUT FRC Radiator
    - OR Trade PLUS Cash for The Following:
    - 1979-1987 C10 Square Body SWB. That is the only trade I will take right at this second. It needs to be running and not rusted out.
    Forged LS2 (32k on Motor) – Built By Jensen Engine Technologies. (Built in 2010 by previous owner) NO LEAKS.
    - “Attitude Cam” installed (222/230 - .581/.591 – 111LSA)
    - Compstar Rods
    - Callies Crank
    - Mahle Pistons
    - ARP Bolts
    - 4” PCM4LESS Fender Well Intake
    - LS1 Electric Fans – Harness done by Stumps’ Garage
    - XSPower Longtube Headers & Catted Y Pipe (Slight leak where y pipe connects under oil pan. Slip connection that I could not get sealed. Can be welded.)
    - Tuned by Stumps’ Garage
    - http://www.jensensenginetech.com/
    - Magnaflow Muffler
    Rebuilt GM Trans Under Warranty 55k Miles on Trans. NO LEAKS
    - B&M Transmission Cooler
    - 3K Vigilante Stall
    Interior
    - Every option except NAV & SunRoof
    - No tears in the seats
    - Minor Blemishes on Plastics in Front & Rear
    - Stock Stereo - XM - 6 CD Changer
    - Flip Down DVD that works with remote
    Exterior
    - Couple of Minor Scratches on passenger rear doors
    - Cleared Headlights
    - Blacked out Taillights
    - Blemishes on corner of passenger doors from road salt from previous owner.
    Previous Owner Installed The Following
    2012 – New Starter & Tires
    2013 – New Power Steering Pump, new front axle & wheel bearings
    2014 – New Plugs, brake pads, & ignition module
    Comes With:
    - Custom Radiator by FSR. Purchased the radiator with the intentions of installing. Never opened the box because work took up too much of my time. It’s winter now, and the stock radiator does fine. It will need the radiator installed for the summer. The stock paper thin GM radiator does not cool well here in South Texas.
    - Spare Ignition Module
    - Spare Low Beam Headlight Relay
    - Stock untinted Tail lights
    - Oil Pan (Came off another truck)
    - Stock Engine Cover
    - Spare Tire & Jack
    - Air Compressor Lines/Fittings
    - Stock GM Manual
    - Stock Cam
    Idle Video -
    http://vid39.photobucket.com/albums/...pspcvy9709.mp4
    Pictures
