Still having problems with codes 171 and 174!
Truck still shows right and left banks are lean. Truck will sometimes (normally cold) idle between 1000-1400. Other times (normally warm) it will idle normally around 650-800 and then drop suddenly to 350-400. Other times it will idle as if nothing is wrong at all. I think it has to be and intake leak, expanding and contracting with the heat. Anyway to test this?
- You may not post replies
- You may not edit your posts
