Another HELP! Different issue different truck
ok so on my 81, i put in the 2002 5.3 4l60 in it. at first i ran a walbro 255 inline pump. it couldnt keep up. so i put in a aeromtoive intank pump. worked great for about 6 months. then it just randomly died. then it started up but acted like it couldnt keep up. so i changed the fuel pump again to an ac delco pump. worked great last night when i test drove it for about 8-9 miles. im like good deal it works. so i drive it to work today. works great till the last mile or so then it starts acting like theres no fuel. and it only when u give it gas in gear. at idle its fine and in park and give it gas its fine. im tired of changing pumps and im tired of not being able to drive it. its not throwing a check engine light. i dont know if maybe its a sensor going bad or a connector is loose somewhere but i would thing it would throw a code. i cleaned the ground on the frame for the pump and re ran a whole new power wire for the pump. also i dont know if it has anything to do with it but sometimes randomly the fuel gauge will read full or empty when its not full or empty then it will catch up i guess you could say to what it really is then go back to either full or empty like its getting a mis reading or bad ground. kinda like when you unplug the oil pressure sensor and the gauge goes to the max. help would be greatly appreciated.
btw im running rubber fuel hos to and from the tank. a friend used the same stuff and his truck is fine.
- You may not post replies
- You may not edit your posts
