Results 11 to 20 of 31
Thread: Good News & Bad News
  1. #11
    test drove it & still runs bad. not sure what to do now. i'm trying to find a better scan tool to see if we can get some more info.
  2. #12
    Sep 2011
    What's the fuel pressure at now?
  3. #13
    get a laser temp gun and go shoot your exhaust looking for cylinders cold or much hotter than others. You may have a clogged injector. An injector balance test could be done. You could have a bad plug, plug wire, coil, injector or who knows what else.
  4. #14
    fuel pressure at the rail is now 58-60 psi. i sent the injectors off during the swap & had them bench cleaned & flow tested. they said everything looked great, flowed & tested perfect. plug wires & plugs are new, along with the O2 sensors. i'll probably pull the plugs & see how they look tomorrow, weather permitting. i think i really need someone to plug into it & see what's really going on.
  5. #15
    Jan 2007
    Crandall, TX
    Quote Originally Posted by RPM Graphics View Post
    Where do you live?
    06 CC 4/6 drop
  6. #16
  7. #17
    Jan 2007
    Crandall, TX
    New Orleans area.
    Well, I am in the Dallas area. If your were closer I could help.
    06 CC 4/6 drop
  8. #18
    yeah, i know a bunch of people in TX that can help, but no one close to me.
  9. #19
    just hooked up my tach & noticed it doesn't move till i'm at about 3-4k. think something could be wrong with my tune?
  10. #20
    What year model tune is in the pcm? One year in paticular has an issue with dri ing a tachomer and you have to put a resistor inline with it to make it function properly.
