Okay... correct me if I'm wrong Greggo... but would it be possible to run the 255 off the stock wiring and control module? That would eliminate the need for a regulator (return line too), and allow me to tune for fuel pressure.
don't see why you couldn't use the stock wiring but I'd upgrade the wiring in the tank to larger wire if possible. Did your's have the variable speed controller?
I haven't had my truck until this evening so I haven't been able to check. I will be checking tomorrow evening. Would it be possible to use the VSC though?
