Originally Posted by
dlt76028
That truck is all motor? How did you measure the tire slip?
which truck? mine yes but you knew that lol the other NO its a procharged head cam fully bolted truck
like quick mentioned i had some old marks i checked them they were about 2 inches from being connected to each other, i checked each pass as i had to check tire pressure in one slick, one slick will hold pressure just fine the other leaks down, the one that leaks down leaks pretty quick if i am below 13 figure i would try 13 psi then when i was in the staging lanes it dropped to 11 after that run i checked the marks again from point a to point b it was about 6-8 maybe a little more, didnt break out the measuring tape
cjriojas
nice meeting you skeet. Your truck is def one of my favorites. I believe in the N/A
nice meeting you also chris!!
Simple: 408 on steroids!
single digits coming soon!
