Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Thread: You OK boys...
    Sep 2006
    THE 405
    Quote Originally Posted by rutroe View Post
    What's with the clutch fan? I thought everything now had e-fans...unless that picture isn't of the actual engine he's selling...which is another issue.
    thats just on the 1/2tons
    midweststreetcars.com
    Arent all the 2500HD's diesel?
    And also I don't think they put L92/LS3 heads on a anything but the L92/LS3. I think this is a sever rationing of bs the dude is using to try and make a penny.
    REALLY??????????
    Learn something new every day. I thought that they stopped offering gas motors in the HD trucks. I was wrong.
    The LY6 6.0L is the standard motor on ANY 3/4 and 1 ton applications--trucks, vans, or Suburbans. IDIOT.
    The only diesel that was offered outside of a truck up until the LBZ was the Hummer H1 Alpha...and it had an LLY. The LBZ was optioned in the trucks and vans--but the vans had a de-tuned version that allowed it to be mated to the 4L80e.
    Quote Originally Posted by sleeper1500 View Post
    all gen 4 6.0's have the L92 heads
    Quote Originally Posted by parker View Post
    Yesch. All 3/4 and 1 ton applications have the mechanical fans because of heavy duty towing and load conditions. Even though e-fans work well, the mechanical fan is best suited for larger trucks/towing applications.
    Guys, from what I see, it looks legit. The motor is from a 3/4 truck--which is the LY6...which has the 353 hp rating, "LS3" heads," AND the VVT. The 6L90e is standard on the 3/4 and 1 ton trucks.
    What makes the hp rating lower is the iron block and truck intake. The L76 is the aluminum block with truck intake and 367 hp.
    Jun 2009
    Washington DC
    I was wondering the same thing
    Schertz, Tx
    Devin, your sig quote is awesome!
    Sep 2006
    THE 405
    ^^^yep
    Roma, Texas
    gen 4 motors on 6.0s are ly6=iron block and l76=aluminum block both with l92 square port heads. stock hp dont matter if your going full bolt on. then you will have home made slicks like i do,lol.
    [CENTER]
    GLADIATOR 6.0 2007 nnbs chevy 13.2 1/4mi. busting my drive shaft at 106 mph before the finish line
    CHEATER 6.0 2000 gmc xcab lq9 fully bolt on 12.52 motor and 11.62 n2o.
    http://youtu.be/UV-I1mlKcTI
    OMG.
    All 2500's are diesel? Read the 8100 topics LOL.
    Clutch fans, find them on EVERYTHING with a 2 or 3 in the 6th VIN place.
