Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
Thread: Weird vibration
  1. #11
    that sux,,what drop kit u have?i go 120+ with no problems
  2. #12
    Jun 2007
    maine
    i was having the same issue with my truck. the pinion angle was off and at 70mph it was vibrating pretty good at 90 it was unbareable. i shimmed my trans and rear end and got the pinion angle pretty close to where it needs to be i can do 110 now before it starts vibrating pretty bad. but im running 4:56 gears and id imagine my drive shaft is spinning pretty darn fast at 110.
  3. #13
    slidelll
    Quote Originally Posted by STUNNA View Post
    custom apllied racing sportsman four link with strange coil overs
    wtfan18 what is you pinion set at and your drive shaft angle??
    http://www.streetsourcemag.com/ViewOwnerProfile.aspx?ProfileID=39253[/url]
    http://s133.photobucket.com/albums/q...sizerst/truck/
  4. #14
    Jun 2007
    maine
    Quote Originally Posted by FullsizeRST View Post
    currently my trans is at 0 degrees and my rear end is set at -1 id like it to be at -2 or -3 but i need a bigger shim.
  5. #15
    Round Rock, TX
    since you have a 4link out back, you really need to make the pinion match the tranny or get it close. Example....if tranny is pointed down 3 degrees make the pinion point up 3 degrees if the tranny is higher than pinion. And since you have a 4link you don't need to overcompensate for pinion roll like a leafspring setup...
    Also when you are measuring, reference everything to the bottom of the frame under the cab. Don't go off the ground...
