Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: 3:23 to 4:10 =retune?
    ff_jeff Guest
    + go easy for about a day. but dont worry too much, the g80 will break anyways.
    There's no need to break in a used part. By definition, it's already broken in. Install the retuned PCM after the gears.
    Okeechobee, Fl
    Do you really think with my mod's + 4:10's a G80 will detonate? Eventually I do plan on putting a 100 shot on my truck will the g80 not hold that?
    49 Ford F1
    ff_jeff Guest
    Tough to say, but everyone I know here that had one that fragged will tell you not to get a g80.
    ff_jeff Guest
    I was told by my install guy and by Rons machine, that My my gears are pre worn a little, and since I had a used auburn pro, I didnt really have to break them in. But I did just to be safe. in about a week or 2 when I buy the diff cover, ill check and see if there is any metal on the magnet. I would be more worried about the gears, than the g80 on wear.
    +1
    the stock gov lok works and can hold up. heres the thing if you abuse it it will break. plain and simple. doing doughnuts, burnouts and just constantly trashing on the truck will eat the diff alive. mine held up for years of driving and track days. what went in mine was the clutch pak and plates inside decided to give out.
    you can get best carrier in world if you trash on it it will also break. if you dont abuse truck the stock carrier will last
    +1
