Originally Posted by
Quik
now im curious to as why you think the 3.5 will be fine with precision specifically made the outlet 4". Parish also stated having backpressure issues with the pt88 and a 4" exhaust. He also has spoke of rpms in the low6s but you say that combo can turn high rpms. i asked on Ls1tech about spinning my 408 close to 7k with the pt88 and everyone spoke up saying it would run into backpressure issues past past 6300.
Mighty mouse doesnt even turn that many rpms and you want to do it with a larger motor. should of went with precsions 91mm turbo instead.
the problem more lies on being a T4 flange and high rpms
i believe you made the 3.5 downpipe instead of 4" for cost of price, which is fine for most ppl but why go thru all trouble of spending good money on a large motor and good turbo and cheap out on using a small downpipe? the cost difference isnt enough to offset the build
