And you will have to install spacers and longer bolts.
hey guys im about too install my 68lbers in my truck,am i gonn need spaccers an if so were do they go?i bought allens 68s i know i have to have to the clip kit that i purchased also but i think i have to space em,im also installingaftermarket fuel rails so idk if i still have too prepare myself to have anything else.sorry too jack u ,off i go .lol.
I used a longer bolt and cut some 3/8" tubing to use as spacers. If you install the injectors in place you can measure how long to make the spacers and longer bolts.
what are the stock 8.1 injectors rated at? And you can run these in a 5.3 with the stock tune right?
01 Silverado RCSB 5.3
N2O and a few bolt-ons
7.33 @ 93.7
New s/u
370 ci
6.91 @ 99.7
Prostreet Motorsports
Rock On Transmissions
