Well I promise I didnt mean that for anyone else since I directly quoted you
So if someone asked you why your truck is black and not grey...THE ONLY ANSWER to it is that the manufacture painted it that way???? I mean couldn't you argue that its black because you wanted it that color. or because the manufacturer ran out of paint on that dy and decided to make 100 more trucks in black to save up and i ended up getting one!?!? My point being theres more than one answer for not buying the LS2 (ALUMINUM) Block other than price!! YES YOU ARE RIGHT!!!!!!!!! PRICE IS A HUGE ISSUE, but, I merely gave him another thing to look at especially if he decides to go much further with his project than you or I. Im shooting for 1200hp 1200ftlbs. Turbo'd and Direct port N2O...I would not recommend starting that kind of platform on an Aluminum block because, NOT ONLY DOES IT COST MORE but, It has a HIGHER chance to crack when under alot of pressure+added LOAD of the vechicle!!! You talk about how the manufacture makes some of these trucks with aluminum blocks, YES YOU ARE RIGHT but, Are these trucks used for towing?? Are they EXcab fullsize trucks? Crew cabs?? Or are the SSR's?? I dont know of any BONE STOCK 2500's with aluminum blocks!?!? Did GM say oh "F" it lets just make an IRON version of the aluminum 5.7l to add more weight to the trucks!?!?
