Page 12 of 32 FirstFirst ... 2 10 11 12 13 14 22 ... LastLast
Results 111 to 120 of 316
Thread: my official build thread
  1. #111
    After I got that all done, I swapped the 4.10s for some 3.42s and put 6 degree pinion shims to fix the pinion angle. I kept having fuel pump/pickup problems. It kept getting air in the line somehow and kept cavitating. I had the bed off at least 6 times and the pump apart 3 times trying to fix it. Here are some pics of the inards of the pump.
    I had been eyeing the aeromotive fuel cells with the built in A1000 pumps since I started the build and I decided to bite the bullet and get it so I would be done with the fuel system and not have to worry about it anymore. It came with a one wire sender that I wouldnt be able to use with my in-dash level gauge so I took the stock one off the bucket, trimmed it to fit in the hole, made a bracket to mount it in the Aeromotive sender location and used the float that came with the Aeromotive one. Here are some picks of the sender fab and some mounted pictures.
    Since then I made up some hoses for the two vents and that runs underneath the truck. I also have a MSD 2 step I got from my roommate and at 2900 rpm on the footbrake I can build 6psi so It should rip if the slicks hold which they should. I plan to make a trip to the track soon after a little tuning and see what it does on 9psi. Im thinking it should be bottom 11s as is and I hope to get it into the 10s on pump gas so we shall see.
  2. #112
    Sep 2011
    This is my favorite build thread on this site! Awesome job your doing, keep it up!
    99 rcsb silverado...... boosted.
  3. #113
    Thanks man!! Ill post a video of the 2 step at night... shooting flames haha!!
  4. #114
    Two videos of the 2 step at 5,000 rpm. The amazing comentary is from member DSCZ71
  5. #115
    Rockwall, TX
    Quote Originally Posted by o2camaross View Post
    Hell yeah!
    How bad did the mpg go down with the th400? May swap one back in when i blow this 60e up
    1989 RCSS 5.3/4L60E swap
    - 224/230 .581.591 112lsa,
    - 3200 Stall
    - DJM 4/6 drop
    - Nelson Tuned
    Building the truck GM never did..
  6. #116
    I didnt do the exact math but I drove little over 300 miles the other day all interstate and I went between 150-175 miles on half a tank. My cell is 20 gallons so if I low ball it thats about 15mpg. Thats cruising at 65mph. I was getting 17mpg at 75mph with the 60e with the lockup converter and 4.10s. Now its no OD, no lockup and 3.42s. But its running a little rich so I can probably get another 1-2mpg out of it. Its steady at 14.3 afr on cruise so I will learn it out to 14.7-15.0 and see what I can get. The slight drop in mpg was way worth the peace of mind and The TH400 ratios matched with the 3.42s is perfect! I beat that c6 vette just rolling into it in 3rd. We went from 70-100 and I just kept pulling!
  7. #117
    Rockwall, TX
    I use to have a th350 In the truck before I did the swap.... Just never had power behind it.... What do you think the top speed will be on it?
    - 3200 Stall
    - DJM 4/6 drop
    - Nelson Tuned
  8. #118
    accounting for 10% converter slippage, a 28'' tire with no growth and the 3.42s I should be able hit 145 easily before hitting the 6800 limiter
  9. #119
    Sep 2011
    Whats the cooler on the fuel cell for?
  10. #120
    Filter?
