Results 1 to 10 of 15
Thread: OBS AC pump and 80e flywheel
    Mar 2013
    Long Beach California
    i thought i would be able to use the LS pump but after reading it looks like the two systems work differently and its not that difficult to mod a bracket for the old pump to work so im just going to stick with that but my pump is shot. anybody got a good used one laying around from their old motors?
    also need a 80e flexplate for the trans swap. idk what shipping costs but if its a good price ill take it. shipping to 90701
    thanks!
    CALI LEGAL ENGINE SWAP!
    Make sure the AC compressor you get has the same amount of grooves in the pulley to match all your other pulleys
    My old compressor was a 5 groove so I have to buy one for a 91 camaro to get a six groove
    Spiro, Oklahoma
    I've got one, It worked great when I pulled it. Let me know if your interested and I'll get you pics of it.
    1991 Silverado-L33 5.3L, 212/218 .557 .562 115+4, ASP under drive pulley,180* thermostat, 90mm truck intake w/ LS3 throttle body. Shoenfeld conversion headers and duel Flowmaster exhaust. Performabuilt LVL 1 transmission and 23-2500 stall converter.
    Mar 2013
    thanks for the heads up mike. didnt even think about that. but it did confirm my ls pullys are def 6 groove.
    that being said, im interested in your pump low91 but is it a 6 groove? maybe your is the same as the camaro since they are both 91's? let me know. pics would be cool
    Mar 2013
    oh and i just picked up a flexplate from another member yesterday so thats off the list!
    Spiro, Oklahoma
    Mar 2013
    Great pics. Thanks man. But it looks like you have a 5 groove... Hard to tell from the pics. If so then it looks like I won't be able to use it. Can you confirm?
