I have Been dealing with the truck smoking more and more each time on startup. It gets worse and worse each time you drive it for long periods and then let it sit. According to most people they say it is the PCV valve in the drivers valve cover...and I am guessing they are right because I popped my valve cover off (2005) and you can tell theres a baffle built into it. But I am wondering if there is any other way to fix this issue other than replaceing the valve cover. I am quite sure it is PCV related because I looked down the intake and there is a huge pool of oil just sitting right inside of it. Right now I have the valve cover soaking in brake cleaner
