Results 1 to 10 of 27
Thread: Tranny acting up
    Jul 2009
    Tranny acting up
    Ever since I got my truck tuned sometimes it shifts quick and hard into 2nd then quickly in third, and there she stays. No overdrive. Can manually pull it down to 2nd. First just won't happen.
    Cut the truck off, sometimes takes a couple times, and she works fine...
    Any ideas???
    Need to scan for codes. If it's electrical or even hydraulic in many cases there will be a code in history. I can think of several things that could cause some of that but not all...especially turning it off and back on making it do right. May have some sediment in the valve body.
    Jul 2009
    Hmmmm.... that's another idea
    04 Silverado Z-71 Extended Cab
    Magnaflow, 10.4 TV 50 wires, tr-55ix, Synthetics, HID's, JL audio, 33.5", leveling kit, tuned, CAI, vette servo, cam, valve job, pacesetter. 9.3@77.5 and 14.5@93.4
    06 2wd
    custom cam, tune, 3.73's, servo, HID's, 10.4mm wires, long-tubes, CAI, magnaflow, 2.5" shackles, Circle-D 3200, UD, JL Audio 4.1, Alpine 5ch
    Jul 2009
    Here is a few codes it is throwing... P0740, 0753, 0758, 0785, and 2761.
    Just a few...
    06 2wd
    spring, texas
    Quote Originally Posted by Tank View Post
    Just a few...
    740 is a circuit malfunction for lockup. This explains the no O/D. 753, 758, and 785 are all shift circuit electrical and hydraulic malfunctions. Most likely your speedo isn't calibrated correctly for your 33's and your VSS is causing havoc on the tranny causing it to go into limpmode. No O/D and no 1st gear are limpmode symptoms. Driving like this will cause major heat in tranny, so beware.....
    2009 YUKON DENALI,BLACK ON BLACK, LS3, Dynomax 4" cat-back, VARA-RAM INTAKE, KOOKS LT's, MSD IGNITION, LS VVT hot cam, ZO6 springs, HP tuned to 421awhp, 12.54 at 108mph on 24's.TUNING FROM THE DARKSIDE.
    06 KAWI BRUTE FORCE 916cc 6.80's in the 1/8th. ALL MOTOR. New found drug addiction is getting "HER" into the 5's. "EVER HAD A QUAD TAKE YOUR MONEY?"
    Mar 2006
    Mesquite
    Must be Allen tuned it.
    Must be another topic but I thought I surmised voltage loss to trans connector...causes electrical default 3rd.
    740 is no converter lock up as posted above and there are several causes. One is obviously to power to the TCC solenoid and when 740 is combined with electrical (not hydraulic) DTC's for both shift solenoids, you have something to go on.
    Hydraulic faults set different DTC's than electrical faults because the PCM knows the electrical is working (feedback resistors internal to the PCM) but does not see the changes on the TFP switch (this switch set sends different signals based on actual hydraulic pressure passages in the valve body). This is how it knows the difference between hydraulic faults and electrical faults.
    Anyway....
    Most cases when you have multiple intermittent electrical DTC's there is either a connection issue (at the trans plug, in the fuse panel) or more likely in the electrical ignition switch.
    There are other things that will happen at the same time as the trans issue if the problem is with the ignition switch although an '04 is not wired the same as some of the older ones that are easier to see. TBC IGN 0 fuse powers the BCM (one leg at least) and has its source as the same as the source for the IGN 0 fuse that powers the trans on the 2004. Remember, there is one hot wire to the trans on an '04 4L60E and it powers all the stuff inside the trans. The stuff inside is all turned on and off with control (ground) wires from the PCM.
    GM bulletin:
    "#01-07-30-002E: MIL On, Transmission Stuck in Second or Third Gear, IPC Inoperative, DTCs P0740,P0753,P0758,P0785,P0787,P0973,P0976,P1860,P2 761,P2764 and/or P2769 Set (Verify and Repair Source of Voltage Loss - (Sep 23, 2005)
    Subject: Malfunction Indicator Lamp (MIL) On, Transmission Stuck in Second or Third Gear, Instrument Cluster Inoperative (Verify and Repair Source of Voltage Loss In Transmission Solenoid Power Supply Circuit )
    Models: 2006 and Prior GM Passenger Cars and Light Duty Trucks
    2005-2006 HUMMER H2
    2006 HUMMER H3
    2005-2006 Saab 9-7X
    with 4L60-E, 4L65-E, 4L80-E or 4L85-E Automatic Transmission (RPOs M30, M32, M33, MT1, MN8)
    This bulletin is being revised to update model years, add additional models and add additional diagnostic information. Please discard Corporate Bulletin Number 01-07-30-002D (Section 07 -- Transmission/Transaxle).
    Condition
    Some customers may comment on one or more of the following conditions:
    • The Malfunction Indicator Lamp (MIL) is ON.
    • The transmission is defaulted to second gear (4L80/85-E).
    • The transmission is defaulted to third gear (4L60/65-E).
    • The instrument cluster is inoperative.
    Upon investigation, one or all of the diagnostic trouble codes (DTCs) P0740, P0753, P0758, P0785, P0787, P0973, P0976, P1860, P2761, P2764 and P2769 may be set depending on the vehicle.
    Cause
    The most likely cause of this condition may be a loss of voltage to the transmission solenoid power supply circuit. "
    What did I leave out?
    BTW, don't know what 2671 is unless it has a letter other than P in front of it.
    spring, texas
    Wasn't in the GM print off you posted above.....
    spring, texas
    Anyway....
    GM bulletin:
    2005-2006 HUMMER H2
    2006 HUMMER H3
    2005-2006 Saab 9-7X
    Condition
    Cause
    So his tune has caused a mysterious voltage loss at a solenoid.
    You can read and type out a TSB VERBATUM.
    I remember that ole TSB bulletin center.....ALL the techs who couldn't diagnose where hanging around that area all the time.
    My GM tech manual must be a complete misprint. All the code Def's are wrong....
