When I did my 6.0 install I didn't have the FPR hooked up to the vacuum line, reg went bad after a few weeks and fuel pressure was ~58 psi. Shortly after replacing it, found where to hook up vacuum line pressure is ~44 psi at idle and might get to 50 psi under throttle. The problem is with the vac line hooked up it doesn't run nearly as strong as with it unhooked. Any ideas on whether to do something to the fuel return or what?
