George you thinking ladder bars over 4 link? I know losing the leaf setup would lighten it up a good bit. Shawn, I plan on making some brackets for the seats. I'll take pictures as I go through it. Gotta get cage figured out first
2014 Xsport- 3.5 Eco boost
412 Motorsports
also fastest LSX truck is ladder bar, 2nd fastest I believe is a ladder bar and 3rd {nelson's truck} ladder bar
hayhauler / La Whippet / farmtruck
412 Motorsports
Good deal! Ladder bar is simpler too. You think I would need a rear sway bar?
412 Motorsports
Little update:
I decided to go ladder bars and backhalf since it would be much easier to cut the rails and make new 2x4 rails rather than straighten the old ones and box them in. I just cut the rails and removed on leaf hanger. I have a 12 bolt from a 70-72 chevelle that my buddy gave me so i cut off all the brackets and have it ready to start fabbing up the suspension. Im going with 35 spline axles, spool, c-clip eliminators, and 3.55 gears. The 12 bolt is 6.5" narrower than the 10 bolt so no need to narrow anymore than that. Next thing to do is build the fram rails. Im going to narrow the frame about 3-4" on each side. That should give me enough clearance to run a 18" wide tire if need be haha. Here are a few pics
Cool deal. Keep us updated on ur ladder bar build. Also it looks like the frame bent right at the c-notch which might have actually saved the rest of the frame lol.
Best ET 11.54@114 w 1.52 60ft
Raceweight 4905 lbs.
