Results 1 to 10 of 26
Thread: Trans issue again
    Feb 2010
    Central Texas
    I'm guessing that is with you taking trans out of truck, thats way to cheap for a proper rebuild in my opinion.
    Jul 2010
    Douglasville Ga
    Quote Originally Posted by 96/chevy/pu View Post
    X2 too cheap.
    If the fluid is dirty the clutches are burned up. It's very important to blow the transmission lines and cooler out completely.
    Not doing this will just cause issues on the next rebuild.
    A tune won't cause a trans to slip or burn up. A trans tune consists of adjusting shift points. Increasing line pressure for a better feel and removing TM.
    Any tuning application available cannot change the function, the way a trans operates, so it's really hard for a tuner to hurt a trans.
    Jan 2012
    Anacoco, La
    Ok, I was just trin to eliminate my options, I'm not sure why the same thing happind so quickly with a diff trans. I know what parts I need to stop the problems in for round 300 for parts I think I can fix it. I'm not a trans guy but Evan they started some where lol.
