Results 1 to 10 of 11
Thread: cam suggestions
    cam suggestions
    i have read in many posts in many forums that there are better cams than the Z06 cams to go into a 5.3
    z06 cam
    '01, 385hp p/n 12560950 duration 204/211 valve lift 0.525/.0525 lsa 116
    '02-'04, 405hp p/n 12565308 duration 214/218 valve lift 0.555/0.551 lsa 117.5
    im putting a 5.3 in my 97 chev sub but i wanted to change the cam before i install the engine
    Can someone please suggest something?
    Arizona/Utah
    I would just get a simple off the shelf cam in the 212/218 range if you don't want to run a stall. Matching springs and hardened push rods are a given. The 214/218 cam is a good option. If you are willing to run a stall then you can easily jump to a 22x/22x cam of your choosing. To get a really specific cam we need more specs on your build. Supporting mods, gears, boltons, future plans, etc. The Z06 cam isn't worth the time unless it's free or really cheap.
    97 chev sub
    4.10 gears
    maybe a 2400 stall
    i'm installing the z06 intake with injectors also
    i need a cam that will help get the sub moving quickly
    need to have a smooth idle
    thanks
    Arizona/Utah
    That is real easy then 212/218 low lift LSA 115 however the idle will be more based on the tune than anything.
    However, I would keep the truck intake as with the LS6/z06 intake you will gain up top but lose bottomend.
    when you say low lift, what numbers are you talking?
    thanks
    Arizona/Utah
    Quote Originally Posted by slicpartna View Post
    thanks
    Idk the exact specs, but I will look for them. When ordering it just says low lift. I would guess in the .52x/.52x range.
    Round Rock, Texas
    Anything bigger than a 212ish cam and you start to move the power band up. Whats the purpose of putting the cam in? Stock replacement, or wanting more? You need the long runners of the truck intake to keep the torque down where you actually drive in the powerband. Gaining a few HP at 3500+ is not worth losing torque at 2000 rpm.
    Quote Originally Posted by Duct_tape123 View Post
    wanting more out of the engine
    i'm thinking 2400-2600 stall
    The 212 218 .522 .529 114 is a real nice cam , I just put one in a 6 liter and it runs real good. Torquey cam.the tr220 is another proven cam.you can always get a custom cam through Nelson , with all your specs and a cam that will suit your needs.
    Quote Originally Posted by CHEVROLADE View Post
    are the specs on the TR220 with a 1.5 rocker ratio?
