Results 1 to 10 of 178
Thread: 94 Lifted Silverado 6.0/4L80e swap Build
    Jun 2009
    Caledonia, MI
    Quote Originally Posted by 92 6.0 View Post
    Its real easy. Just find the brake switch in your truck. Its on the pedal up under the dash a lillte bit. And then look for the purple wire and splice the one from your swap harness to it and your done.
    Do you know which wire I have to splice it into on Nelsons harness? Because their harness is a 4 wire hookup, and that doesn't include a wire for the brake
    Silverado Z71 10" Lift COMPLETE 6.0/4L80E PRC 2.5 Ported LS6 Heads 228r Comp Cam 3200 CIRCLE D Stall LS7 Lifters ARP Bolts SLP Oil Pump and Double Timing Chain 160 T-Stat 3" SLP Loudmouth Electric Cutout Walbro 255 Pacesetter Longtubes MSD Starter NELSON Harmess NELSON Street/Strip Tuned ECM MSD Wires LS1 Throttle Body Braided Lines Spectre CAI 4.56 Gears Detroit Locker 14 bolt http://www.ls1truck.com/forums/lsx-t...wap-build.html
    Quote Originally Posted by HPICamaroSS View Post
    This wire is supposed to be with the dash group speedometer,tach...Also did you wire your park neutral switch? The pcm need to know when you are in gears..
    Sorry for my bad English I'm french!
